biff44
Advanced Member level 6
- Joined
- Dec 24, 2004
- Messages
- 5,059
- Helped
- 1,376
- Reputation
- 2,748
- Reaction score
- 1,060
- Trophy points
- 1,393
- Location
- New England, USA
- Activity points
- 37,988
If you had an IC with a true differential input, and you were trying to measure the differential return loss using a typical network analyzer (single ended port 1 and port 2 available for S11 and S22 measurement), can you make a differential return loss measurment?
I tryied calibrating S11 with a broadband balun in place, and did not get a very good return loss indicated when measuring two 50 ohm loads.
I also tryed calibrating S11 with a DC-6 GHz balun with 3 dB pads at the two ouputs, and once again, got very poor VSWR when measuring two 50 ohm loads, (even worse than the hybrid).
Any tricks, other than renting a 4 port network analyzer?
