qamesh
Hello,
Hi, I am experimenting with differential outputs on the Arty A7. For this, I am using the 100MHz clock and have instantiated an ODDR then OBUFDS -- . I Have also looked through the 7-series Select-IO Resources User Guide and the only differential I/O at 3.3V is TMDS_33 IOStandard.
The .xdc file has the following --
## Pmod Header JB
set_property -dict { PACKAGE_PIN E15 IOSTANDARD TMDS_33 } [get_ports { buff_out_p }];
set_property -dict { PACKAGE_PIN E16 IOSTANDARD TMDS_33 } [get_ports { buff_out_n }];
Pins E15/E16 are HR I/O banks [JB1/2] and they should work fine.
Synthesis & implementation are fine and I can generate a bitstream, but I see no output on these pins (just 0v)
I also tried to connect a termination resistor of 50 ohm pulled up to 3.3 V as recommended for FP_3.3_50 [OFF chip termination]. but it gives nothing...can anyone help me in this?
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ODDR #( .DDR_CLK_EDGE("SAME_EDGE"), .INIT(1'b0), .SRTYPE("SYNC") )ODDR_CLKADC( .Q(buff_local), .C(buff_in), .CE(1'b1), .D1(1'b1), .D2(1'b0), .R(1'b0), .S(1'b0) ); OBUFDS #( .IOSTANDARD("TMDS_33") // Specify the input I/O standard )OBUFDS_inst ( .O(buff_out_p), // Diff_p output (connect directly to top-level port) .OB(buff_out_n), // Diff_n output (connect directly to top-level port) .I(buff_local) // Buffer input );
## Pmod Header JB
