MuroSamuro
Member level 4
Hello there,
I have yet to design a differential pair TL, so I came up with this fundamental question:
Say you design a single ended TL that is connected at its both ends to coax cables which are connected to a calibrated vna. To avoid reflections, the characteristic impedance of the TL should be the same as the coax cable.
However, in a differential pair you design for a specific differential impedance, which could be acheived for many values of isolated characteristic impedances (typically marked as Z0).
My queation is, should I design the isolated characteristic impedance (Z0) to be equal to the coax cable impedance to avoid reflections ? Or deaigning the differential impedance alone is enough?
Thanks
Thanks
