differential apmplifier problem
jutek
Full Member level 4
Full Member level 4
hello
could you tell me what max gain i can achieve from circuit like this in the picture but with PMOS as the inputs and NMOS as a load?
i'm trying to simulate that with different currents and W/L ratios but the max i've achieved is 10V/V
What is incorrect? my expectations or calculations?
regards
probably 10 is the correct number. the gain is Gm(nmos)/Gm(pmos).
the gain is not big
because the output pmos is diode connect.
so the output resistance is small
so, if i want to build 2 stage opamp i have to use another input stage to have much more gain?
regards
you can refer Allen's book ,chapter 6,Cmos operational amplifiers.
