ahmad_abdulghany
- Joined
- Apr 12, 2005
- Messages
- 1,206
- Helped
- 102
- Reputation
- 206
- Reaction score
- 22
- Trophy points
- 1,318
- Location
- San Jose, California, USA
- Activity points
- 11,769
differential amplifier above rail
Hello all ..
I want to use ADS to design this easy problem as a tutorial for it ... but i don't know where to start and how !
Please if anyone can help me to design such diffrential amplifier ..
It is a differential amplifier gain stage with the following c/cs:
- Works with resistive loads.
- The required gain is 30 dB and the maximum output signal swing is 3.4V peak-to-peak differential.
- The supply voltage is 3V.
- The current consumption should not exceed 200 uA (micro Amps).
- The design is to be implemented in 0.35 µm technology ( I had attached a SPICE model for it .. but don't knwo how to do similar model for the ADS )
If insteed you can give help in OrCAD PSPICE this will be great
Please try to help with many thanks ...
Note that i am poor in using the ADS
Hello all ..
