susanne0s
Newbie level 2
diffrent results in hfss feko and cst
Hope everybody are good.
Please find attached full question with diagrams.View attachment Question.pdfView attachment Question.pdf
A coax-fed patch antenna with dimensions given in table below, is simulated in HFSS, CST and FEKO
softwares.
It is seen that:
The results of the CST software in the case of
- The phase Z component of the electric field on the line parallel to y axis
and
The results of the FEKO software in the case of
- The magnitude of X component of the electric field on the line parallel to y axis
- The phase of X component of the electric field on the line parallel to y axis
- The phase of Z component of the electric field on the line parallel to y axis
- The phase of Z component of the electric field on the line parallel to x axis
and
The results of the HFSS software in the case of
are completely different from the results of the two other softwares (despite partial similarity of the field
behavior in other cases).
The question is why it is such different.
softwares.
It is seen that:
and
and
