difference in LEF and GDS views....
kambadia
Newbie level 5
Newbie level 5
Hello every one what will be the difference between .lef and .gds. As far as i know both are physical views..So is there any difference between them...
GDS contains complete mask layer information of the design . Where as lef has the pin information mainly
LEF is a reduced view for place and route tool, which include at least the metal layer which are manipulate by the PnR tool.
Rhe description will include obstruction and pins.
LEC:logical equivalance check
lec is one of the formal verification method
lec is performed after synthesis
GDS:GDS II is a database file format which is the de facto industry standard for data exchange of integrated circuit or IC layout artwork
"Graphic Data System"
LEF not LEC ;-)
LEF:Library Exchange Format
in cadence tools we use LEF
in synopsys tools we use .tf(technology file)
this LEF/.tf contains the info of technology mapped gates with timing,power,area...etc info for each and every cell that is being used in our design
I think Timing and power info will be in .lib
