difference Hspice and Pspice
Full Member level 4
Full Member level 4
I designed very simple RC circuit like that.
vac 1 0 ac 120v
r1 1 2 200
r2 2 0 400
c1 2 0 10u
.ac lin 1 60 60
.print ac vm(1,2) im(r1) vp(1,2) vm(2) vdb(2) vm(1)
.end
when I run it in Pspice & Hspice, the results is different.
but I don't know why
*Hspice result
freq voltage m i mag volt phase voltage m
1 r1 1 2
2 2
60.00000 48.5219 323.3326m 26.6866 71.4781
*Pspice result
FREQ VM(1,2) IM(r1) VP(1,2) VM(2)
6.000E+01 6.467E+01 3.233E-01 2.976E+01 7.148E+01
why is so different in voltage magnitude ? especially VM(1,2)??
in my opinion, Hspice may be correct. how about your opinion?
I donot think that I could say HSPICE is right or pspice is wrong.
If u were using MOS obviously model modelling in HSPICE are better that in PSPICE, but u are using R and C and ideal elements.
Both H and P (spice) are solving the same set of equations (Kirckoff lows) to get the result.
The results are very close.
Since they use diferent algoritms to get the results, some diferences in the final numerical result is expected.
Both results represent the aproximation of the exact solution.
This is a normal behavior.
I want a someone who can explain me about this difference in detail
difference in algorithm ?? that's so invalid...plz... explain in detail.
