iVenki
Member level 3
I confuse the terms "power" and "power dissipation".
I know that the power dissipated through a resistor is I^2 R or VI. But what is the power of the dc supply?
What is the formula for both of them?
Both seem to have the same formula.(ie VI)
Then what is the difference between them?
---------- Post added at 16:30 ---------- Previous post was at 15:30 ----------
If you say the formula for power supply is also VI then I have one question.
Consider that I have two batteries. The power of a dc supply is always a constant. It means that when the current increases then Voltage should increase but total voltage always remains same (For example consider two circuits having different resistances( and hence different currents) will have have the same potential when each of them is connected to a battery).
I can't understand this. Please help me .
Thanks in advance.
Thanks in advance.
