Difference Between Synchro Transmitter and Reciever
bilal shareef
Member level 1
Member level 1
Hello everybody,
Can anybody tell me about the difference between the synchro transmitter, synchro receiver and synchro transformer.
Because when I saw the internal structure of all the three (synchro transmitter, synchro receiver and synchro transformer) I found no difference in the internal winding
And if there is not any difference can we use synchro transformer in place of synchro transmitter
Synchro transmitters and receivers are electrically identical. ... The difference between a TDX and a TDR is that the TDX is a torque transmitter and TDR has electrical angle inputs on both the stator and rotor.
So, I can use synchro receiver as a synchro transmitter .. Right ?? switychandra
Actually I have a motor in which their is a built-in synchro receiver whose shaft is coupled with the motors shaft so I can use that receiver as a transmitter to locate the current shaft position of the motor.. Right ??
