Difference between pickit 2 starter kit and debug express
catcha03
Newbie level 6
Newbie level 6
CANADA
I'm planning to buy a pickit 2, I'm wondering which is better among the 2.
Depends on you requirements
Starter kit includes an LPC Demo Board, while DE includes a 44 pin demo board.
As far as the capabilities of Pickit2 is concerned it the same for both S.K and D.E, meaning pickit2 is the same only demo board is different, for all practical purposes pickit2 only will be as good as a programmer/debugger as the one with demo boards.
The Starter board, though small, does allow a little room for you to add on a few extra bits of your own hardware, but the chip fitted does not allow you to use the Debug function of Mplab, though it is not necessarily a feature a beginner would want to use.
The Debug Express is really small, about 3cm square, and has all smd parts.
It is not an easy board to expand.
Both are good boards to 'get you going' but you will soon find your will be building you own larger boards.
