Difference between NMOS/PMOS with and without Deep Nwell
hafis.m
Newbie level 1
Newbie level 1
I there any difference between NMOS/PMOS inside DNW and outside DNW in terms of IV characteristic like IdVg, IdVd, gm?
Can I use a normal NMOS to run ADE simulationto get IdVg of an NMOS inside DNW or vice versa?
I would assume they would behave almost the same. If you have a device inside DNW, this means you have the option to connect its bulk terminal to a different voltage and not necessarly to the most (positive or negative) terminals.
Why cannot you use NMOS in DNW directly in simulation?
If deep nwell is -only- deep and does not abut the
surface, then it can isolate a P pocket for NMOS which
is no different than the plain epi / bulk. There would be
a regular NWell for PMOS which is different. PMOS in
deep Nwell without regular NWell would probably be a
depletion-mode PMOS.
