Incorrect read Fault (IRF) : After reading operation, the cell gives incorrect logic value...but stored bit is not faulty.
Read destructive fault (RDF) : When performing the read operation, the stored bit is changed....this is happens because the less timing difference between the read and write clock....so it doesn't have proper timing to stable...
