vraupp
Newbie
Hi guys,
I'm simulating an antenna on the HFSS driven terminal (Lumped port) and I've come across the following situation:
In edit sources, when using incident voltage, the Incident, accepted and radiated power quantities are altered when I change the impedance of the port. In other words, I can see the amount of power absorbed by the antenna depending on the impedance match.
This is not the case when I use the total voltage. In this case, when I change the impedance of the port, only the incident power changes, and the accepted and radiated powers remain fixed.
I would like to better understand this phenomenon and the difference between the two forms of excitation.
Thanks
Thanks
