simplsoft
Full Member level 2
Hello
Can anyone tell me what is the difference between filter and amplifier.
If an active filter is designed using OP-AMP or OTA then we also have gain of active element. It can amplify as well as filter out irrelevant frequency component from the signal. Similar is in an amplifier if amplifier is designed then also has gain and it amplifies signal. It can also work upto a certain frequency limit lets say if the amplifier amplifies signal upto 100KHz then it can also be like a low pass filter that allows frequency to pass upto 100KHz.
So then whats the difference?
Thanx
Thanx
