Difference between direct and indirect synthesizers?
vco96
Member level 1
Member level 1
I'm reffering to signal generators.
Thanks
This nomenclature (direct vs. indirect) sound "old".
almost every syntetized generators are "indirect".
Direct:
An array of N fixed frequecncy oscillators (i.e. 1,2,4,8,10,20,40,80,100,200,400,800MHz)
An array of N mixers.
With appropriate switch bank you may get an output freq. from 1 to 1665 MHz with 1 MHz step. Lowest phase noise but expensive and large.
Indirect:
The PLL are indirect
The minimum step is smaller as the dividing factor is large. Fmax/Fmin depend on VCO and typically is 1 octave. Phase noise is moderately low, in most cases is low enough.
DDS:
The waveform of the out signal is "syntetised" point by point.
Extremally low phase noise, but few spuriuos signal near the carrier.
A short note about stability:
Phase noise (or FM noise) far from the carrier depend on synt. technology. But phase noise close to carrier depend to the frequency standard only (i.e. the Quartz).
In addition:
DIRECT:
Sweep speed limited by the switch speed (tipically us).
Spurious frequencies reduced up to 100 dBc.
high resolution
DDS (I think iy means DIGITAL Synthesizer):
High sweep speed
high resolution
fmax limited by reference frequency
spurious frequencies (due to D/A converter) may be high (50 - 60 dBc)
