- Joined
- Apr 1, 2011
- Messages
- 15,639
- Helped
- 2,913
- Reputation
- 5,838
- Reaction score
- 3,055
- Trophy points
- 1,393
- Location
- Minneapolis, Minnesota, USA
- Activity points
- 117,099
A resistor develops a voltage across it, due to current going through it. This voltage can be detected by an op amp (or ADC in a microcontroller).
It's just a convenient way to measure current through equipment.
The sense resistor usually has a low ohm value, so that it has only minimal effect on the performance of the equipment.
As for how to design an MPPT, a microcontroller can be programmed to try a different level every few seconds, and use the level that is greater than previous.
I did not undertake to make an MPPT, and I'm not sure I would be able to do so by using simple analog circuitry (eg., op amps).
I made a simple On/Off charge controller for my PV panels and battery bank. It had an op amp which sensed battery voltage, and a mosfet which controlled current from the panel.
