Difference between a NMOS source follower and PMOS source follower
hrkhari
Full Member level 4
Full Member level 4
Hi Guys:
What are the significant difference between a NMOS source follower and PMOS source follower. Thanks in advance
Rgds
Re: Source Follower
NMOS high speed than PMOS. But in the usual p-substrate process, NMOS source follower will have harmonics distortion caused by body effect since NMOS's substrate cannot be tied to the source.
Re: Source Follower
The body effect mentionned by terryssw will also make the gain less than 1, due to gmb. PMOS could be closer to 1, but still lower.
Other main differences I can think of:
- PMOS will create a positive shift in your DC point whereas it will be negative for NMOS (about Vth).
- Noise performance migth be slightly better with PMOS
Re: Source Follower
Hi Guys:
Thanks for your beneficial inputs, is there any particular effect in the use of High Frequency circuitry (RFIC)?.Thanks in advance
Rgds
Re: Source Follower
In RFIC, due to the speed constraint, it's necessary to use NMOS.
