Diff pair mismatch and tail current
Tahar
Member level 3
Member level 3
Dear All,
Is differential pair mismatch reduced by a higher tail current or a smaller one ?
Did not figure out yet....maybe something to do with Vov.
Thanks.
pair mismatch is usually effected by area. you should find some things from report of foundry.
The differential pair mismatch is reduced by lower bias current if W/L is fix.
    Tahar
Thanks, any idea about hot to derive the equation showing that ???
ΔVth=σ/√W*L you can get σ in mismatch report from fab. σ depend on process, about 4~7mV.um
I know this equation (hopefully), this is not what I am looking for.
I am looking for an equation of the form: mismatch=f( Ibias).
Thanks anyway.
A higher Vgs (i.e. a higher current) would give better mismatch for a tail current.
Intuitively, this can be explained by the fact that for a given delta Vgs mismatch, higher Vgs would mean smaller impact ( since selta vgs is small compared to vgs, the corresponding delta I would be likewise small).
A derivation of the equations can be found in Grey & Meyer's book "Analysis and Design of Analog Integrated Circuits, 4th Edition"
The equation of mismatch caused by I is:
Vos= sqrt(I/(2K'W/L)×(Δ(w/L)/(w/L))1-2 - Δ(w/L)/(w/L))3-4)
Hope this can help!
there is a key equation at P.379 of Razavi. about the offset.
the summary is the more offset when the bias current is larger.
