Die components by itself?
Thevenin
electronic die component
Hi all!
this is my new post here. Nice to meet you.
Please, I always have been asking myself why electronic componentes fault by itself, I mean the life span util of a component.
I understand the problem with electronic capacitors, but semiconductors they fail due the electromigration; as far as I know this happend only in integrated circuits, but then, why discrete semiconductors has they own life span? Wich is the process of a transistor o diode die by itself?
Thank you for reading.
Semiconductors died because thermal fatigue.
Several turns on & off of devices expands and contracts semiconductors cristals and finally it died.
If you turn on a device and don't turn it off is less probably that it died, MTBF in always turn on devices is normaly 20 times devices that are turned on & off.
( MTBF is medium time between fails ).
Solder joints have the same problem.
    Thevenin
Thanks brumi, very helpful your answer.
