walker8764
Junior Member level 2
![Junior Member level 2](/styles/images/ranks/clevel2.gif)
ic5033 8-bit pseudocolor
I installed IC50 under RH7.2, and run "icfb", there is error message :
" Failed to find either 24-bit TrueColor or 8-bit PseudoColor Visual"
My display card is Intel 82845G Graphics Controller, and in my XF86Configure file the default color depth is 16bit. I tried to change the default color depth to 8bit, can run icfb, but the display is abnormal. And can not run under 24 bit.
I spent much time on this problem, Any body can help ?
thanks a lot!
thanks a lot!
