Dialing up GPRS/GSM network in uClinux via RS232
xczms
Junior Member level 3
hangzhou, china
dial-up in uClinux
dose anyone have experience in dialing up GPRS or GSM network with GPRS modem under Linux or uClinux through serial port RS232, could you give me some tips? which software should i have? ppp tcp/ip rs232 driver, anything else?
Re: dial-up in uClinux
You should not use PPP, as PPP will do too much thing than normal GPRS connection.
For connection with GPRS: you need two AT commands:
AT+CGDCONT=1,IP,156.090.123.076
ATD*99#
Please note that the above two is just a example, you need to consult your operator for the actual one.
After this connection, the system can now on the internet world, you can do the TCP/UDP/IP... protocol
