peterhull
Newbie
I bought a used Wolf pole saw recently with an 18 volt lithium Ion battery and charger. The battery is fully charged but the charger is dead. I have checked that it is receiving 240 volts at the circuit board but there is no output. The battery has 6 cells in series.
The battery has 3 terminals labelled positive, negative and T. I guess the T terminal is something to do with balancing the charge. I have a sophisticated charger IMAX B6 AC which can be used to charge all sorts of batteries. I tried to programme it charge the battery but it came up with an error code ' connection error. I only used + and - terminals.
The IMAX charger has a balancing connection for charging 6 cells. I really need to advice on how to make up a connection system from my IMACS charger to the existing battery in order to charge it properly without error messages. Would appreciate any advice please.
