dht222 shows check sum error
mshh
Full Member level 6
Full Member level 6
usa
this code works well for dht11 but for dht22 it shows checksum error in the range from 49-51%.
I tried to put it in a code #but there is a problem
Chip type : ATmega8
Program type : Application
AVR Core Clock frequency: 8,000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 256
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
#include mega8.h
#include stdint.h
#include stdio.h
#include delay.h
#include stdlib.h
#define DHT22       //define DHT22 or DHT11
#define DHT_PORT        PORTD
#define DHT_DDR         DDRD
#define DHT_PIN         PIND
#define DHT11_PIN 1
// Alphanumeric LCD Module functions
#include <alcd.h>
uint8_t c=0,I_RH,D_RH,I_Temp,D_Temp,CheckSum;
 int q;
     float RH;
   unsigned char data [5];
void Request()                /* Microcontroller send start pulse/request */
    DDRD |= (1<<DHT11_PIN);
    PORTD &= ~(1<<DHT11_PIN);    /* set to low pin */
    delay_ms(20);            /* wait for 20ms */
    PORTD |= (1<<DHT11_PIN);    /* set to high pin */
void Response()             /* receive response from DHT11 */
    DDRD &= ~(1<<DHT11_PIN);
    while(PIND & (1<<DHT11_PIN));
    while((PIND & (1<<DHT11_PIN))==0);
uint8_t Receive_data()          /* receive data */
    for (q=0; q<8; q++)
        while((PIND & (1<<DHT11_PIN)) == 0);  /* check received bit 0 or 1 */
        delay_us(30);
        if(PIND & (1<<DHT11_PIN))/* if high pulse is greater than 30ms */
        c = (c<<1)|(0x01);  /* then its logic HIGH */
        else            /* otherwise its logic LOW */
        c = (c<<1);
    return c;
void main(void)
PORTB=0x00;
DDRB=0xFF;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0xFF;
lcd_init(16);
while (1)
       Request();       /* send start pulse */
        Response();     /* receive response */
        I_RH=Receive_data();    /* store first eight bit in I_RH */
        D_RH=Receive_data();    /* store next eight bit in D_RH */
        I_Temp=Receive_data();  /* store next eight bit in I_Temp */
        D_Temp=Receive_data();  /* store next eight bit in D_Temp */
        CheckSum=Receive_data();/* store next eight bit in CheckSum */
        if ((I_RH + D_RH + I_Temp + D_Temp) != CheckSum)
            lcd_gotoxy(0,1);
            lcd_putsf("Error");
        else
            lcd_gotoxy(0,0);
            lcd_putsf("Humidity =");
            lcd_gotoxy(0,10);
           #ifdef DHT22
            RH= (float) I_RH * 256.0 + D_RH ;
            RH=RH/10.0;
            #else
            RH =  I_RH;
             #endif
             sprintf(data,"%.1f%%  ",RH);
           lcd_puts(data);
                delay_ms(2000);
In some cases, it is necessary to invert the calculated value and add 1 (or alternatively, add a minus signal); moreover, the method you are using do not seem a good choice, once you are not checking when the calculated value equals to the one received, but you are checking if it differs. I presume you should have to do something like this:
if ((I_RH + D_RH + I_Temp + D_Temp) == - CheckSum)
I'm assuming that compiler will not perform any kind of type casting to 16 bit on the above sum.
