casey480
Junior Member level 1
All,
I am synthesizing a basic design with three clock domains and the occasional negedge flop. To make reordering not an issue for negedge flops, I invert the clock with scan_mode. The scan_mode signal is generated from a flop within the design. The tool reports
at many points throughout the synthesis and scan insertion process. There is very little mentioned about this on Solvnet.
My questions:
1) Does this cause the tool to needlessly iterate and burn area, attempting to meet half cycle paths?
2) If so, what is the best way to fix it? I invert two different clocks in the design. At one point in my synthesis, I must have added a constraint or changed the design such that one clock stopped reporting a unate-ness warning. I'm not sure what I did, and it's very confusing!
Thanks!
Warning: A non-unate path in clock network for clock 'wdt_clk'
from pin 'user/wdt/U46/O' is detected. (TIM-052)
My questions:
Thanks!
