Syswip
Hi folks,
As I know the output of the DFT is N times more than input.
I'm doing 16 point DFT. My input samples are in range -32768..32767.
It means that the maximum value of the output must be 32767 * 16 = 524272.
But I found the input sample sequence which DFT result is more than the
maximum value mentioned above.
Is it possible?.
Thank you very much.
Tiksan.
Is it possible?.
Tiksan.
