Device Ro (1/gds) Change from Schematic to Extracted Post-layout
fpmkh0
Newbie level 6
Newbie level 6
Hi, for those with experince, can you please help me understand the reason for device output resistance (ro) change from scheamtic to post-layout? It's for a 7nm technology. I checked the current and it's almost the same. For the reference, Ids only -1%, gm is also almost the same. But I noticed ro droped by almost 17% post-layout. Any explanation? I checked multiple devices and I notice number of multipliers affects this. For example, for a device with 32 multiplier, ro droped by 7% while for a device with 256 multiplier, ro droped by 17%.
If your extraction includes resistance or inductance then you can
see source-degeneration degrade gm@OP, especially at higher
drain current. It's likely also that post-extract models (which tend
to play with the partitioning of what's "inside" and "outside" a
device, may embed "stuff" that makes a straight model:model,
device:device matchup show differences. Like, in RFIC flows I
knew, the post-layout model tree's subcircuits would have R
and L and C burdens while the schematic model did not (the
designer was responsible for best-guessing all that, in "paper
space").
You could test this theory. It comes down to cases in PDK
development.
LaTeX Commands Quick-Menu:
