Device questions with answers (doc with graph)
mysslynn
Newbie level 5
Newbie level 5
device questions
I have attached a graph that goes along with these questions. I guess I am just having a hard time figuring out where to begin.
Re: device questions
Here is a complete solution for your questions...
If there is anything you dont understand, just ask...
thank you so much.
Added after 37 minutes:
actually, I do have another question.
If it says:
Device A is connected in series with a 15-v battery and a 2k resistor, determine current. How do I use the graph to solve this question. I guess I just dont know how to use the graph.
another example:
Device B is connected in parallel with a 5-mA current source and a 3-k resistor. Find voltage across B and current through it.
Same problem. How does the graph apply to these?
