flamingo
Member level 4
I am using a network enviroment in simulation, that is, all the user files are located in a fileserver, while the cadence main programme is located on another server.
There is no problem when I run the simulation first time, but when I want to simulation again icfb will tell me " *error* request.il asiiStart: error in start function, request withdrawn ("deleteFile" 0 t nil ("*error* deleteFile: device or resource busy" "/home/simulation/username/.../schematic/psf/.nfs0579700084d")).
The .nfs file can not be deleted in command line also. And the file can only be deleted or may disappeared automatically when the icfb was shut down. But this can not be a method.
By the way, We changed into the network mode not long ago, and there were no similar problems encountered before when we do the simulation at local server, that's mean that all the user file and cadence main programme are all located in a single server.
We judged maybe there are some problems in network configuration, like mount file. If anyone encounted simulation situation, pls help me, thanks a lot!!!
