Development FPGA board with Gowin chip
FlyingDutch
Advanced Member level 1
Bydgoszcz - Poland
Hello, forum,
some time ago I published a post related to the FPGA board based on the Gowin GW1N-LV9LQ144C6/I5 chip. See post:
I ordered PCB in JLCPCB and then mounted the prototype. I checked this FPGA board with some FPGA projects and all hardware components are working properly (I also checked PSRAM and external Flash). There was a FTDI USB programer for the FPGA chip and it also work fine with "Gowin Programmer". After checking all components I implemented NEORV32 (RISC-V) soft-cpu on this board and it worked fine. See the link to the project:
https://github.com/stnolting/neorv32
The second edition of PCB has been designed. This version is more professional - some things has been improved:
1) Power planes
2) All high-speed signals and differential pairs of I/O pin traces are designed with length-matching
3) the size of the PCB is smaller
4) PCB has been designed for small EMI emission
This board is well-equipped with peripherals and has 64 I/O pins lead-out for headers. Every I/O bank can be powered by 3.3V , 2.5V, 1.2V voltages.
Here is screenshot from EasyEDA Pro CAD:
And here is 2D image of board:
3D image of teh FPGA board:
Regards
LaTeX Commands Quick-Menu:
