Developing parser and scaner in Visual Basic
snaider
Member level 5
Member level 5
Parser and scaner
I want to make a compiler for a microprocessor I am doing in VHDL, a have the instruction set a I just want that the compiler take a txt file with the program , and give an another txt file with machine code. I think visual basic can make the interface part but it also can do the scaner part of the txt file and parser(do the grammar part) too.
Re: Parser and scaner
depends on the programming language
if youre making a C compiler, dont even start. the whole thing will be enormous
take a look at gcc source - huge
if youre doing ASM code, you could use visual basic for the convertion, and it should be relatively easy. you just need the datasheet for the target ic
Parser and scaner
What you need is lex and yacc. This is the normal way to do it. Bit of a learning curve though.
Those table driven assembler are a good idea. Exist any who work with a windowns interface , not just DOS.
