Hi all. I have a plan on trying to use a simple PWM averaging using RC filter. By Googling I have found some information about determing the RC value. It seems that the higher PWM freq we use the better. I't's kinda a rule thumb.
My question is, how high should it goes? Is it merely depends on the uC (generator system) capabilitiy (incl. design requirement) or is there somekind of a golden rule there? If there is not any "golden frequency" then what is the most common frequency used (if there is any of such) and also why (the technical background)?
I guess, you want to use the PWM circuit as a DAC. What are your requirements in DAC terms? Resolution, update rate, settling time? What are the available hardware PWM parameters of your microcontroller, respectively the expected frequency, resolution and accuracy of a software pwm solution? You'll notice, that there several absolute limitations and possible trade-offs. Do some calculations and you'll hopefully understand.
Thx for replying randell :smile:
I was thinking about using it as DAC (FvM has pointed that out) feed into voltage regulators feedback pin such as LM317, LM2576 and such. The reason I'm asking is that people, especially engineers, usually picks many rule of thumb along the way :smile:
---------- Post added at 23:20 ---------- Previous post was at 22:51 ----------
Hi FvM, first contact ... thx for reply :smile:
You are absolutely right, I have a thought to use it as a means to control voltage regulator. You have what they use to say, a senior instict, I guess. I am trully sorry that this time I cannot provide you the detail of my design simply because there is simply none, yet. In this phase I'm just looking as many information as I can to re-read and synthesize later on. I have a reasonable basic knowledge of electronics but it cannot be said as a good working skills, so you might get "the picture" now. But here is what I have in mind already ...
I'm planning to use Arduino (Mega then my own built NG board, the older) as the controller. If I succeed I will look forward to implement it on a system with atmega8/atmega8535/atmega32/attiny2313 as the controller, depends on what other system function dictates. I suppose learning pwm using Arduino is very straight forward than directly on the bare AVR. As I remember most Arduino operates with 16MHz crystal. I have no other plan yet to share the uC time budget, sole purpose is as the pwm controller. Other function I will learn to add later, as the basic digital power supply works well.
I hope I can manage to have 1.25V (or better 0V) all the way up to 15V, for the first effort system.
I have found this in Wikipedia:
"The PWM switching frequency has to be much faster than what would affect the load, which is to say the device that uses the power. Typically switchings have to be done several times a minute in an electric stove, 120 Hz in a lamp dimmer, from few kilohertz (kHz) to tens of kHz for a motor drive and well into the tens or hundreds of kHz in audio amplifiers and computer power supplies."
I have read elsewhare about similar project, mainly based on the PICs. But I cannot find the common "usual value" as stated in the Wikipedia for other apps. Since you mention it, limitations and trade-offs, I sens that too (the reason I'm asking). But I am crawling in the dark here. If you can elaborate more, I will be gratefull, FvM.
If you increase the switching frequency you get lower losses in the magnetics, smaller capacitors and magnetics (transformers/inductors), but higher losses in the electronics (FETs and diodes).
I will be back to ask more information about limits and tradeoff I try some experiments myself.
---------- Post added at 05:53 ---------- Previous post was at 05:45 ----------
Hi Tahmid. Thanks for the link. I will study all reading materials that I already have so far. Then after I did some experiments myself I'll be back asking for your experience about those losses trade-offs.
I just picked up a couple Arduinos to play around with, mainly to checkout the Arduino programming environment. I have a few links to PWM projects using the Arduino, I'll post them here later today.
AN565 linked by bigdogguru and the PWM tutorial linked by Tahmid is referring exactly to your DAC application. Main performance parameters are resolution respectively accuracy and speed/settling time. If speed isn't a primary objective of your design, then selection of PWM frequency and filter dimensioning isn't very critical. For high resolution (12 to 16 Bit), you'll end up with a rather low pwm frequency and slow filter. I've been using active 2nd order low-pass filters in this situation to get low ripple and an acceptable settling time.
PWM for switch mode converters, which has also been addressed in some contributions, is a different topic and imposes different requirements.
Why don't you just try? Newer BLDC fans have input capacitors and don't work well with simple on-off PWM. Best behaviour can be expected with low PWM frequencies in this case.
Small motor inverters work well with 16 to 25 kHz. Almost no audible noise, acceptable losses. It's usually not reasonable to go for higher PWM frequencies.
