Detector of short connection location
stanislavb
Full Member level 2
Full Member level 2
It difficult task to find location of short connected traces especially short connected power plane on PCB
I am interesting if exist equipment which can assists with it?
Thank you
you need a logic pulser to put 10 NS pulses of 100mA into the circuit and a current tracer probe to see where the current is flowing to. HP make both of them , other may do as well.
Frank
Reactions: tpetar
    tpetar
In many cases, DC voltage drop is suitable. Requires a constant current lab supply and a sensitive (micro)voltmeter.
Reactions: tpetar
    tpetar
Attach a high current power supply and let it rip. The place that heats up the most is the most likely culprit. Use your finger to trace the heat if you are brave, use a FLIR IR meter if you are wealthy ;)
Do you remember part number of this kit.
Thank you
Frank
