Detecting of a IR signal, How COM works on IR?
bws
Junior Member level 2
Denmark
infrared signal irda
hey
if you need to do this, what is the easiest / smartes way to do so ??
and how does the com. works on IR ?? when for exsample a remote sends a signal to a tv ??
i have found some standards IR remote´s comunaction is "build" by, but what a about the hardware side ???
thx in advance
how to make a infrared signal
Do you want to build the IR detector your self? I am sure that there are both the "transmitters" and "receivers" out there and you just have to build the interface. How to communicate with it depends on the brand, read its data sheet. In my previous company, an engineer did it in a week, so I thought it was not that complicated.
getting ir signal 2009
i have a IR detector, but how does it respones to IR signals ??
i just need to detect any tv-remote signal ..
Re: Detecting of a IR signal
A simple PIN diode or IR receiver may help. Just ensure you have a low pass filter cascaded, where 38-40kHZ of remote control signals can be filtered out. There are also few other concerns you have to exclude in the design, like sunlight cancelalltion etc.
