Detect number of bit change in one clock cycle
mpatel
Member level 4
Member level 4
Germany
How can I write a VHDL code to detect the number of bit change..
For example I have 4 bit register A. The value of is A = 1100. Now it is changed to A=1010. So how can I detect how many bits are changed?
Is there a solution to detect in single clock pulse?
Thanks
Please find the simple flow with verilog code
assign no_of_change = data_dly ^ data_in;
always @(posedge clk)
data_dly <= data_in;
for (i = 0; i=3; i = i+1) //it will implement the combinational logic
count = count + data_in;
this count will give you the number of changes.
Regards,
Kanags
Let Q(3 downto 0) be the output of shift register.
process(clk)
if (clk = '1' and clk'event)
if(A(3) = Q(3))
count <= count+1;
end if;
if(A(2) = Q(2))
count <= count+1;
end if;
if(A(1) = Q(1))
count <= count+1;
end if;
if(A(0) = Q(0))
count <= count+1;
end if;
end if;
end process;
So, finally this COUNT gives the no. of bit changes
you can simply XOR every delayed version of a bit with it's present value, so with every change in every bit you'll suddenly detect the change(instantaneously with just a very very tiny few delay).
now you can add the resulting bits together in one clock cycle and get the number of them.
a : signal std_logic_vector(3 downto 0)
dlyd_a : signal std_logic_vector(3 downto 0)
c : signal std_logic_vector(3 downto 0)
res: signal std_logic_vector(3 downto 0)
c<= a xor dlyd_a;
process
begin
if rising_edge(clk) then
dlyd_a <= a;
res <= c(0)+c(1)+c(2)+c(3);
end if;
end process
I'm not sure about the syntax error's but you can easily modify it yourself...
    mpatel
