logicengineer
Newbie level 1
I am designing a PIC16F based project which incolves detecting a metal ball-bearing passing through a pipe. The ball is about 26mm in diameter.
I have to design a system to detect the ball passing though a pipe.
Initially I intended to use IR Tx and TSOP (1738) to do so, but apparently - the TSOP has a noise filtering mechanism which just ignores the ball passing at the velocity of gravity.
I chose TSOP to avoid the interference from external light, as TSOP 1738 only observes IR at 38kHz.
What alternative do I have for such a high response time, and yet be secured from interference from external light?
