DesignWare VIP problem!
wagewage
I want to use DesignWare vip in ntb. Is that OK?
when I compile ntb with vcs7.1,errors occure:
..........line 101 : Error: unsupported Vera construct 'vera_shell_param' encountered
" ", line 0 : Error: unsupported Vera construct 'attribute decl' encountered
What does that mean?How can I solve this problem?
Anyone who knows that!
hi wagewage ,
let me know about how to use DW cosine and Sine function?
how its works?
if u dont wanna use that function. how can i write my won code for cosine and sine function in combinational.
sorry i dont know to answer ur questions.
thanks in advance
aravind
aravind said:
hi wagewage ,
how its works?
thanks in advance
aravind
You can either use a lookup table or use CORDIC algorithm for implementing SIn/Cosine generator. for using DW sine/cosine checkout the datasheet of the component from sold.
whizkid
i dont wanna implement in both ways (cordic or lookup table). i wanna implement in combinational logic , how synopsys design cos and design function.
sin x = 1 + x3/3! +x5 /5 ! ........
can u please give me some idea?
    wagewage
HI wagewage,
You must setup the VERA environment. Synopsys VIP need use VERA to generate all test vectors.
And check your license.
Good luck
    wagewage
hi zhustudio,
thank you very much!
