ramin.ala
Junior Member level 1
I should design a band-pass filter at 10 GHz with 500 MHz bandwidth. No matters the size or structure; but that must have very low insertion loss at pass band (below 1dB in practice and 0.5dB in simulation) and good rejection at 9.5 and 10.5GHZ (about 40dB). Also I want low-ripple in pass band.
I tried microstrip structure but that wasn’t satisfactory (The insertion loss was about 2.5 dB in simulation with HFSS and ADS momentum).
Then, I tried Cavity structure but I can’t design the structure for that frequency band (I use Ansoft designer for designing process but the results were too small with disappointing results in HFSS)
Someone suggests me SIW (substrate integrated waveguide) structure. But I have not any idea for designing this structure.
I will appreciate if anyone can help me for Cavity or SIW designing at this band, or any other help.
Thanks in advance.
Thanks in advance.
