Designing switching transformer
tictac
Full Member level 5
Full Member level 5
Polland
Hi
I want to make one SMPS with this specification:
V(in)=24v DC I(in)=10A (two sealed acid battery)
V(out)=2500v DC I(out,max)=20 mA
I want to calculate N1,N2,B(max),L,gap length with minimum capacitive effect and skin effect with good isolation .
please help me.
by regards.
designing a transformer
I want to using full bridge topology .
please help me out.
B(max)=170 mT
regards
2500V output - the voltage spikes will kill yours output diodes. Delete inductor on output of transformer - after diodes. And set it anywere befor the diodes.
Added after 2 minutes:
use the brige rectifier on the output. It's the only right way, I guess.
there is a diode that suffer 20kv on forward and switch fast and prevent spike at output because of its fast on/off time. do you suggest your circuit about this?
by regards.
