Designing SIM900 Module to run on Power Bank of 5V output
SiddharthGajjar
Junior Member level 3
i've designed the supply from the thread we discussed here on edaboard and finally ran 1n5408 based circuit:
https://www.edaboard.com/threads/349641/
We had designed a SIM900 Based Modem board and our application is to upload data using 3G data connection.
the schematic Eagle file is attached here with this.
i am using intex power bank of 11000mAh
now problem arised is like when i insert SIM card ( Vodafone, IDEA) it registered with network when i checked it with AT+COPS? command
the BAND selected is EGSM_DCS_MODE
for one minute it holds the network registration then it disconnect from it. and modem has reset and once it left the network it doesn't connect again until i unplugged from source and plugged it again.
my modem is not in sleep mode
we have interfaced smf05c ic fro SIM card interface.........
i think SIM 900 is going sleep mode and doesn't reponding......
whats the problem.....
  • SIM900.rar
had anyone observe my schematic .............. is there any problem with that?????
:thinker::thinker::thinker::thinker::thinker::thinker::thinker::thinker:
Network lost + Reset of modem = Power supply current limitation.
My advice : Use the power supply schematic given by the constructor.
Choose the file called "SIM900 Hardware Design" in **broken link removed**
off topic:
as far I know sim900 doesn't support 3G
