JUBAYER
Junior Member level 1
I was designing a power supply for my personal use with L7805CV, L7809CV,L7812cv for fixed supply and LM317T for variable supply. The problem is, can i use a single heat sink for all those ICs? or it will short all the output of the Ics to a single node. Also i am using TIP 42 for high current supply. Now if i use one heat sink for all 7800`s and another for all the TIP42`s, is that OK? and also i need suggestion for 1W 0.3Ω 1% resistance?
