Designing a DC converter for positive to negative voltage
sunknu
Newbie level 5
Newbie level 5
Hi all
I am considering to design a DC Converter which can convert the positive voltage to negative voltage. Does any one have ideas about the componets, schematics of it, ...vv..
Thank in advance
Sunknu
mc34063 boost 180v
sunknu said:
Hi all
Thank in advance
Sunknu
There are many and many as ICL7660, MC34063, . . . . .schematics and the another informations which there is in the datasheet.
Good luck for U !
Re: DC-Converter
Thank you for your advance, but I want to convert high voltage DC. ex from 180V to -180V. Could you give me another advance?
Re: DC-Converter
These kind of questions always make me ask more question sorry in advance. I assume that the positive 180VDC you are starting with has a hard reference you can not change. Otherwise just make the positive side of this voltage referenced to gnd and there you go a negative voltage at 180Vdc. If this is not an option then.....How much current do you need? What kind of regulation does the -180VDC need to be within. What kind of efficiency do you require. What other voltage or power sources are availible. Line voltage ?
regards
dfullmer
Re: DC-Converter
If you do not need isolation, you can try an inverting regulator. It works like a boost, but the voltage is negative. It is sometimes referred to as a buck-boost, although I personally do not agree with the name.
If you need isolation, then a flyback is the way to go. The output can then be of either polarity, depending on how you connect the output.
Re: DC-Converter
Hi
to VVV: Thanks for your idea. I will try.
to dfullmer: I need a power source. I have a positive power source and I need a negative power source. But I am not good at power conversion. So Could you give me more detail about it.
Re: DC-Converter
Sorry sunknu,
I been a bit busy, VVV is correct about the buck boost and the flyback. The files are a few circuit configurations that may help you decide. The link to the book is one that may help with the rest of the construction once you make the decision.
h**p://rapidshare.de/files/32989892/Newnes_-_Power_Supply_Cookbook__2001_.pdf
Regards and Good luck
dfullmer
ps the scans are from Solid State Power Conversion Handbook by Ralph Tarter
Re: DC-Converter
Thank for ur books. I am going to read it.
Re: DC-Converter
Can you post the other requirements, such as output power (or current), etc?
Re: DC-Converter
Hi!!
I want to design a 24V-12V dc @5A-7A power supply to connect some car elements (12V) to truck battery (24V). Any suggestion???
Thanks in advance...
Regards,
togarha
