Designing a 2-bit comparator using FSM
quocviet19501
Newbie level 6
Newbie level 6
Hi all, thank for reading my thread.
I have a project that requires a comparator to compare the original data from pattern generation block (TX data) with the data after processed (RX data).
The comparator should assert FLAG as follow:
0b00, 0b11: Prohibited. End of program & assert error & done.
0b10: Passing result. Saving Data, then JUMP to the next address.
0b01: Failing result. go back to resetup data.
If you have any hint, idea, or example, please share it with me.
I appreciate and thank you for paying attention.
could you possibly give us LESS information?
Nobody has any idea what you are talking about. ”JUMP to the next address”? What address?
”resetup data” ??
What’s your system? what’s your data? language?
”resetup data” ??
What’s your system? what’s your data? language? thank you, I have done it
”resetup data” ??
thank you for repling, I think I had found the answer
