Krishhhh
Newbie
Hello everyone,
I’m currently working on designing a 12V, 10A SMPS with the following specifications:
Lastly, how should I validate the design after simulating it? Are there specific checks or tests I should focus on?
Thanks in advance for your advice! I’m excited to hear from you all and get started on this project.
- Input: AC 230V RMS, 50Hz (single phase)
- Output: 12V DC, 10A
1. Topology:
Which topology would be best suited for my use case? Some of the options I’ve come across include:- Flyback, Push-Pull, Half-Bridge/Full-Bridge?
2. Part Selection:
I’d appreciate guidance on selecting the key components:- Transformer: What should I consider in terms of turns ratio, core size, and type (e.g., ferrite core)?
- Rectifiers: What type would be best for my output stage? Should I consider Schottky diodes or silicon-based rectifiers?
- Filter Capacitors: Any suggestions on choosing the right capacitance and voltage rating for the output filter?
- Voltage Regulator/Control IC: Which control ICs would be ideal for this power range?
3. Design Process:
What’s the best way to approach the design of this power supply from scratch?4. Simulation Tools:
I’ve been using Proteus for some simulations, but I’ve noticed that certain components are not available. Are there other good alternatives that might offer more flexibility or accurate results? I’ve heard of LTspice, but I’m not familiar with how comprehensive its library is for SMPS components. Any recommendations on simulation tools would be great.Lastly, how should I validate the design after simulating it? Are there specific checks or tests I should focus on?
