[SOLVED] Design with transfer function
ashugtiwari
Full Member level 4
Full Member level 4
Hi All,
Is it possible to design the circuit with given transfer function with all coefficients and mag and phase plots? Thanks in advance.
Ashutosh
ashugtiwari said:
Hi All,
Ashutosh
Yes, of course - but realize that in principle, you have to select one design out of an infinite number of alternatives (different circuits with different impedance levels).
But that is quite normal: Distinction between circuit synthesis and circuit analysis, which only has one single solution.
Thanks for reply,
if for example the given transfer function is a/(s+a) for first order low pass filter, how to design the circuit elements and have arranged them to work as required.
ashugtiwari said:
Thanks for reply,
It is rather simple:
a/(a+s)=1/(1+s/a) >> a is identical to wG=2*Pi*fG (fG=3 dB-corner frequency)
For a simple RC circuit the corner frequency is wG=1/RC.
