bluethunder7000
Member level 2
transformerless power supply
I need help to calculate the current in each branch of the attached circuit
and i need some answer for :
1:how can i know the max. output ampere from this circuit?
2:if i need more than the expected output current what i should doing in this circuit?
3: i built this ct. on board and it work fine ( giving a 33Vdc Output ) but when i change the capacitor to 2.2µF/275Vac the resistor 100Ω/3watt be warm quikly and burned after few min. So if i need to change the capacitor what i should be doing in the all circuit?
4:when i need to let this circuit to withstand the input voltage from (220 to 350 Vac) Phase to neutral what should i do to make this feature?
5:how can calculate the power of this ct.?
6:when i design any ct. what is the best program which can i use to draw & simulate the circuit and get a very exact results as the real calculations on board?
I really appreciate youe help me in this design
thanks again
thanks again
