design square rooter
kavhra
Hello ,I have designed the square rooter which is in square rooter word file, but two inputs of op-amp aren't equal respect to negative feedback as mentioned and I receive the negative output from the circuit. Can any one help me.
Thanks
The image blown up is totally out of focus.
Try reposting/saving again. And look at result until ist large/clear/in focus.
Regards, Dana.
Would you use an analog multiplier doing Vin*Vin, as feedback
against Vin, taking sqrt(Vin) off the op amp output?
Check whether
* square root is essential (often it can be replaced)
* you can use digital square root (more precise)
Klaus
