[SOLVED] Design Rule Error in Proteus Ares
mmaher22
Newbie level 1
Newbie level 1
Hello,
I have 2 simillar DRC Errors in Proteus Ares for two capacitors in my PCB the Error is
  • Violation type : "Pad-Pad"
  • Layer: Top
  • Actual Clearance: 9.56th
  • spec'd Clearance: 20th
  • Design Rule: Default
What is the meaning of this error and how it can be solved ?
Thanks in advance
The error is self explanatory: The DRC for pad-to-pad clearance is configured on tool as 20"th" but you drew them just 9.56"th" apart. You must move away the pads from each other.
