design procedure of fully diferential folded cascode OTA
wael_wael
Full Member level 4
Full Member level 4
folded cascode ota
Hi every body
i am looking for books or tutorials for design procedure of folded cascode with fully differential amplifier gain boosting, i will use it to design pipeline ADC
kind regards
folded cascode
Hi, I think the book writed by Allen is useful for you.
folded cascode procedure
hi
thanks for replay, but realy the allen book, didnt explain fully diff OPAMP AS well
regards
folded-cascode ota
Rgds
Amarnath
fully deferential folded cascode opamp design
amarnath said:
h**p://www.mit.edu/~ddaly/projects/775_OpAmp.pdf
Rgds
Amarnath
hi
realy many thanx, for that, so helpful, pls if you want any paper from IEEE & pdf books, just let me know
regards
design procedure folded cascode
the design procedure is simple.Just derive the kp and kn and lambda values from simulation.Then do your hand calculations ,and then go for design. i would recommend you refer to maloberti.
amarnath
folded cascode ota design procedure
hi
i dont understand "malobert" it is book name, author ....
and i am looking for differential output, not single out put could u help me
thanks
design procedures of ota
maloberti is the name of the author of cmos analog vlsi design(i dont quite remember name of the book).U can search for this author in this forum.Yes u can design for differential output in a folded cascode. Please refer to this book for the same.
amarnath
    wael_wael
you can download the maloberti here
ieee paper folded cascode design
can anyone upload the maloberti book on analog design
design procedure folded cascode design
wael_wael said:
Rgds
Amarnath
hi
regards
does not exist anymore ... can you upload it. Thanks.
hand calculation folded cascode
the book links davidwong posted is still working.
