carpenter
Full Member level 6
I want to use on a two-layer board STM32F4x7 and LAN PHY LAN8742A , unfortunately I have no experience with PCB design for PHY and I have not found a exmples for it.
1. Digital part RMII
How must the signals tracks be the same length?
I think,for a 50MHz bus this idifferences in length in the order of tens of mm do not matters not critical.
2.Output TX+,TX-, RX+, RX- to be 100 Ohm differentoal pair.
OK, I have problem.
I would like to make do with 2 side FR4 PCB.
On this PCB have 100Ohm Routes approx 0,65mm.
I want to use HR911105A LAN connector with integrated magnetick but this parts have on Pin 1 TX+ an on Pin 2 TX-, unfortunately LAN8742A
has them cross, TX+ on pin 21 and TX- on pin 20.
What with this?
I assume the pins TX+ and TX+ pn magnetics are not swappable?
OK, I have problem.
What with this?
